Hi,
Thinking of getting my rear shock absorber off, and stripping it down to rebuild, as the inner part looks real crap. Does anoyne know if it is rebuildable.... i.e. can i remmove the spring easily, without having to discharge the gas /oil from the reservoir.... ?
Not keen on buying a new shock, as want to keep the bike original....
Advice please....
thanks Alun
Rebuilding shock
- Greg
Re: Rebuilding shock
I don't think it's a DIY job ... I had my unit refurbed by Falcon in Wareham, re-gassed, re-oiled and re-sealed for £60.00 If you need a new damper rod, they can do a full re-con, but budget for about £140.00
The standard shock can be rebuilt but ...handsomejackuk wrote:Hi,
Advice please....
thanks Alun
changing the spring is not a rebuild! And unless you fancy risking your fingers, pay someone to do it for you
