NHK STEERING DAMPER being offered
Post by cobbadiggabuddyblooo » Thu Apr 02, 2009 9:07 am
Got an offer for a steering damper for $150.. Its a NHK precision steering damper... shaft length 380mm... shaft diameter 11mm... barrell length 220mm... Barrell diameter 25mm.. only thing fork clamp diameter is 52 mm..... 11mm too big..I spose this can this be shimmed down??? or is the whole unit for a larger heavier motorcycle as such???
Re: NHK STEERING DAMPER being offered
Post by phuk72 » Thu Apr 02, 2009 9:25 am
do you need a steering damper :?:
Post by cobbadiggabuddyblooo » Thu Apr 02, 2009 9:48 am
I'm sure the .95kgmm springs will improve the headshaking issues but after bolting on at least 15h/p of late its only got worse. Frame/forks/bars wheels been checked by Dave Kellett and alls straight once again after rebuild 12mths ago.
Post by phuk72 » Thu Apr 02, 2009 9:58 am
head shake seems odd - the TRX is an inherently stable bike
mine makes over 100 bhp and, due to the different front end and other changes, is more 'radical' than stock but I still don't need one.
I'd spend some time sorting out your suspension settings (getting the sag right is important) before you spend money
Post by cobbadiggabuddyblooo » Thu Apr 02, 2009 10:28 am
Well like I mentioned the front end spring wise is pretty pityful at present so no doubt this is the cause as originally the bike handled like a dream but forks replaced on rebuild and springs a lot softer there in may lie the problem and with more power and lower gearing and bluespots I'm pushing boundries... :lol: :lol:
mmmmmm spose its pretty simple isnt it.. work on the root of the problem and go from there instead of trying to work on the problem that has manifested and subdueing that...
Post by trixynut » Thu Apr 02, 2009 11:17 am
I'd agree with Phuk: steering dampers can cure the simptoms of the problem, but not the problem itself, and if the bike is set up right (suspension, head bearings, tyres etc) at the front end, the TRX shouldn't need one. Suppose its an extra bit of 'bling' but thats about it!
Post by cobbadiggabuddyblooo » Thu Apr 02, 2009 11:03 pm
Yes bit like a carrot dangled infront of me by a salesman :o .. Gotta keep my mind focused... :wink: Thanks for the kick up the butt guys... Much appreciated :lol: :lol:
amiciangelo
Post by amiciangelo » Wed Jan 05, 2011 11:29 pm
Hi, I'm interested in mounting a steering damper on my TRX 850 and wanted to know if anyone has mounted and the type you have installed (name, model and technical requirements) and if you see a picture of himself mounted on motorcycle. Thanks and greetings from Italy, Angelo.
Post by Killerwhale » Thu Jan 06, 2011 12:31 am
cobbadiggabuddyblooo wrote:Yes bit like a carrot dangled infront of me by a salesman :o .. Gotta keep my mind focused... :wink: Thanks for the kick up the butt guys... Much appreciated :lol: :lol:
I´m thinking of putting one on...but more as a safety when frontwheel is up in air and land on a rough patch. And i guess it would stabilize one handed riding as well.
Kenny
Post by Kenny » Thu Jan 06, 2011 1:20 am
sounds like a damper for a USD forked bike to me
Post by dandywarhol » Thu Jan 06, 2011 1:40 am
cobbadiggabuddyblooo wrote:I'm sure the .95kgmm springs will improve the headshaking issues but after bolting on at least 15h/p of late its only got worse. Frame/forks/bars wheels been checked by Dave Kellett and alls straight once again after rebuild 12mths ago.
Maybe the back tyres a bit tired :?
Post by ekoja » Thu Jan 06, 2011 12:21 pm
Mine use to headshake if I relaxed the grip on the bars, but when I changed tyre brand, the problem went away.
Bridgestones would headshake violently, changed to Metzler, no more headshake.
Rear tyre was Metzler, but as they are hard to come by now,I have changed to Pirelli. still no problem.
Rubes
Post by Rubes » Mon Jan 31, 2011 12:33 pm
+1 on replacing the front tyre. Mine did this on the old tyre - cant remember the make. Replaced with a Pirelli Angel and all good.
