Can anyone tell me what the torque setting is for the bolts that fasten the steel trellis frame to the cast aluminium subframe that holds the rear shock mount and swingarm pivot.
I've looked in both the haynes manual and the yamaha workshop manual and I can't find a setting anywhere
Frame Bolt Torque Setting
Re: Frame Bolt Torque Setting
It's in the Yam manual. Frame and rear arm bracket. M10. 55Nm
Cheers for that.
"rear arm bracket"
Could they not have thought of something better to call it
"rear arm bracket"
Trevor!Terzikat wrote:Cheers for that.
"rear arm bracket"
