What does a TRX engine sound like ?
jake
Post by jake » Tue Mar 04, 2008 10:19 am
Does it have a ticking noise, can you hear the cams, etc ... my one has been rebuild .. AGAIN ... and it pulls really hard, engine brakes hard (so compression is good) but it still has this constant ticking noise. No one has a TRX that i know, so i can compare it.
Also, when im slowing down almost to a dead stop it starts to pop, ive got a full exaust, i dont know if thats normal.
Cheers guys
Re: What does a TRX engine sound like ?
Post by Killerwhale » Tue Mar 04, 2008 10:44 am
jake wrote:Does it have a ticking noise, can you hear the cams, etc ... my one has been rebuild .. AGAIN ... and it pulls really hard, engine brakes hard (so compression is good) but it still has this constant ticking noise. No one has a TRX that i know, so i can compare it.
Cheers guys
I thought it was broke first time i heard it....it´s a tractor!! It ticks rattles etc. etc.
Is it the motor wich pops when going to a halt?
I had small popping jerks when almost at a stop a while back, fixed it with a new chain and sprockets....
Post by youngy » Tue Mar 04, 2008 10:59 am
yup.............^^^^^^^^ wot he said!
jake
Post by jake » Tue Mar 04, 2008 11:06 am
Well that makes me a lot better Killerwhale, because like i said, it pulls hard, stops well, does everything its supposed to, has so much power thru the entire rev range. But still rattles like a tractor.
99 TRX850
02 GSX-R600
02 Hyosung Comet 250
Post by Killerwhale » Tue Mar 04, 2008 11:16 am
jake wrote:Well that makes me a lot better Killerwhale, because like i said, it pulls hard, stops well, does everything its supposed to, has so much power thru the entire rev range. But still rattles like a tractor.
Well, the 1098R kinda sound as if broke to (for other reasons but...) but runs quite nice... :lol:
Post by slow codger » Tue Mar 04, 2008 5:50 pm
:D If you think the TRX rattles listen to a duke on tick over, bag of spanners. If your back firing on the over run after shutting it down then its too rich, TRX's are set up from standard as that, try a K & N air filter.
Dave E.
steve speed
Post by steve speed » Thu Mar 06, 2008 9:43 pm
the backfiring ,,i also believe there could be a problem with the valve in the carb iam not sure what its called but its behind the white plastic disk held on with two screws on the side of the carb
Post by Quan-Time » Fri Apr 18, 2008 1:21 pm
http://www.users.on.net/~auska/bike/tankcam1.aVi
dodgy as hell, but it MIGHT give you an idea of what they sound like..
Reason: to make the link work ;-)
