oil seal
- steve speed
oil seal
Ive just fit a new oil seal behind the gearbox sprocket ,,easy job ,and the new seal is slightly different from the old one , the four tags on the back are bigger and the inner dimension is smaller on the new one ( shaft size ) by .6mm both are genuine Yamaha parts so we will see if this slows down the rate of oil consumption
Re: oil seal
steve speed wrote:Ive just fit a new oil seal behind the gearbox sprocket ,,easy job ,and the new seal is slightly different from the old one , the four tags on the back are bigger and the inner dimension is smaller on the new one ( shaft size ) by .6mm both are genuine Yamaha parts so we will see if this slows down the rate of oil consumption
- Quan-Time
- steve speed
Re: oil seal
i can only take a pic of the the old one ,,is that any use ???
- steve speed
Re: oil seal
Of the job itself of cource!! Duh!steve speed wrote:i can only take a pic of the the old one ,,is that any use ???
Re: oil seal
oil bet it makes no difference atall atall to oil consumption as i replaced it a couple o' years back too, ya did fit it 'carefully' so as none of the tangs covered those oil ways ???? i have pics somewhere........
- burty
Re: oil seal
I replaced mine too and it made no difference whatsoever.
My local Yamaha dealer was sceptical too.
I don't doubt that it might make a difference (actually I do) , but I'm yet to meet anyone or read anyone's first hand report that it made a difference. I reckon this "oil seal causing the high oil consumption" is another internet propagated myth.
- steve speed
Re: oil seal
yes i think your right ,,iam not expecting much inprovement but as i said its a start ,,i will be doing the rings, honeing the bore and replaceing the valve stem seals so fingers crossed
- Kevtrx849
- Moderator
Re: oil seal
Well there you go, you obviously didn't read my report a couple of years ago. My bike uses minimal oil anyway but on the old forum one of the blokes reckoned that if you visually checked your starter motor and found a film of oil on it then chances are your seal is incorrectly fitted. I done that and thats exactly what i found. Checked the old seal when i removed it and yes it was obstructing the oil galleries. New one fitted correctly and my oil consumption dropped from bugger all to 3/5th's of fu*k all.
No oil on my starter motor now except for a bit of chain lube
( HENRY FORD )
( HENRY FORD )
- burty
Re: oil seal
So it's not a confirmed cure for high oil consumption then is it Kev?
Re: oil seal
But for under a tenner, and half an hour's work, it could well be wothwhile. Certainly not a waste of time or money.
