How to - Change your emulsion tubes
- [JP]
Ok.. so I´ve changed mine today so thought about taking some pics and post here in case someone needs to do the same..
sorry if some bits will be refered to bits...as I don´t know the name of them in English..lol
So... take your tank off, airbox and carbs out.
there´s loads of tubes to disconnect and also the throttle cable, but they are easy to do, just note how they were connect before disconnect them
First thing to do is undo all the bolts on the top and bottom of the carb.
then, take the top part (black) and slide the rubber area together with the needle and put it on the side.
now, turn the carb around and undo the 4 bolts on the other side.
take the floaters out and undo the nut on the top of the emulsion tube
and slide that bit out.. (lol..don´t know the name for it)
push the emulsion tube down, it will slide the other way down coming out throuh the top part of the carb.
take the emulsion tube out and replace with the new one and put everything back together..
hope it helps someone out there!
PORTUGUESE MADNESS
- Glen1TRX
- zod
Nice guide JP!
Doing much of the same job my selves these days, with good help from my Haynes manual.
The manual states that you should replace several of the o-rings when putting the carbs back together again. Is this just to be on the safe side, or is it something I'll later regret not doing now?
Don't really want to sit here waiting for the parts when the sun is shining.
- [JP]
Well, I´m no experienced mechanic, but what I do when it comes to seals and o rings is to check if they have any breaks on them...if they don´t I just use the same...
the only thing I always replace with new is engine gaskets...
even when striping and cleaning brake calipers if the seals are fine, I don´t replace them despite the fact Haynes says to do so.
PORTUGUESE MADNESS
- burty
- TonyDevil
get Factory Pro emulsion tubes, not yammie ones
the TDM guys get a discount from Straightlineracing in the UK
(nb: i'm not suggesting you pretend to be a TDMer )
http://www.carpe-tdm.net/ipb/index.php?showtopic=218
TDM900 2003 - commuting tool
Z750 hardtail - project
- G Beale
Re: How to - Change your emulsion tubes
Thanks JP for this guide. I replaced my tubes with factory pro ones last Sunday without a manual and all is well now. Not been out on the bike since but it starts & runs so I'm assuming it's fine ! I managed to split 1 of the tiny coolant hoses which didn't want to come off but it was long enough to trim down. The hardest part for me was re-fitting the throttle cables but I kept at it, swore a hell of a lot even by my standards & they went back eventually.
On re-assembly I found it best to fit the right hand inlet rubber to the engine & the left hand to the carbs so I could still access the screws to tighten them up easily.
