Hi all
Looking to upgrade on my trx (bike currently has yzf 750 6 pots that are rubbish!) i noticed alot of people do the blue spot/ gold spot calipers and was wondering if the calipers from a MT07 would fit as they look identical but are silver instead of blue/gold anyone got any info it they do fit or not?
Also looking at fork upgrades trying to source a set of r1 forks seems near impossible unless paying silly money, i was wondering if it would be worth just having the original forks rebuild and reworked to suit my weight and riding style any tips?
Thanks Ryan.
Brakes and Suspension
- drix
Re: Brakes and Suspension
Hi Ryan
MT07 silver spots will work yes
As for the front end, you have many option available... rebuild the stock ones with stiffer springs, thundercat forks, yzf750, early R1 and more.. depends on your needs & budget. There’s loads of feedback here on such mods, search the forum
Enjoy the thinkering!
Adrien
Adrien
Cartridge emulators for the forks will do a good job.
Hi Ryan, this post was quite a while ago, how did you go with your brakes and suspension? I've changed my calipers over to silver spots and now looking at low budget suspension options - my mechanic is putting heavier weight oil and a small spacer in to see if it makes a difference, but I'm not holding my breath.
Cheers, Jesse.
Cheers, Jesse.
- trixynut
A smaller spacer tube (standard is 130mm) will mean less compression on the springs at standstill, so not sure how that will work with thicker oil? Thicker oil will slow down the suspension travel: do you think your standard suspension is soft?
Sometimes just an overhaul with a clean out, fresh standard weight oil, new seals and covers makes a big difference.
Standard suspension is not great and not that tuneable. Progressive rate springs make a difference and are not that expensive.
Had my R1 4xv forks serviced, resprung & set up for my weight by MCT makes a world of difference
