Air-cut cover 3d printed
OzzieDave
Post by OzzieDave » Thu May 03, 2018 5:49 am
I have uploaded to Thingiverse, a design to print the Air-cut Cover for the STD carbies, search under TRX850.
The finish will depend on where and who does the printing for you, I have used both my local library (South Australia) and a 3d Hub member, the library is cheaper, while you have more control with the 3d Hub member.
I have tested with one of my older designs as in the photo, it worked fine.
Print at least 50% solid for strength and in ABS for fuel resistance. Black is better for UV resistance.
Snod Blatter
Re: Air-cut cover 3d printed
Post by Snod Blatter » Thu May 03, 2018 9:54 pm
Bloody marvellous =D>
Post by davamb » Thu May 03, 2018 11:53 pm
Nice work!
What was the printer you used Dave? I spend around 25% of my time doing Solidworks and Turbocad 3D design and have been thinking about buying a printer for my own use - my boss is too stingy to buy one for us to use for prototyping.
OzzieDave
Post by OzzieDave » Fri May 04, 2018 1:02 pm
The library has a Makerbot I think, I don't have one myself, the 3d Hub member has several, can't remember which brands he has.
mutey
Post by mutey » Sat Nov 14, 2020 2:40 pm
I was spending some time reading chrome translated trx850 japanese blog sites and discovered this little gem :
This Kawasaki part appears to be identical , I believe it is off a KL250 super sherpa
COVER,AIR CUT VALVE part number 14090-1873
