Please assist I am taking bike to track Saturday....first time with Ignitech quick shifter.
What are the best values for Clutch Master time and Pause?
secondly the way the standard linkage set-up is, I had to mount my Quick shifter upside down.
Even with the supplied rods I could not mount it the correct way.
any thoughts on that?
Quickshifter....yelp please
- Racer-unk
Re: Quickshifter....yelp please
Mine is set on 100Ms, if you hit a few neutrals try 120Ms.. I choose not to use the Q/s from 1st to 2nd...
Leave the other at 500Ms as it's just for switch bounce.
Make sure the linkages are all nice and tight with no slop or extra movement.
I've just gone through and shimmed all the brake/gear shift lever pivots on my rearsets to tighten them up to take out any excess play plus where the ball joints mount too.
- Racer-unk
thanks Cobba....you are a star
