I have a set FCR41s which are now ready to be fitted ( they were off an XTZ750 so had shorter spigots, any how I had new spigots machined up by a mate ) , my question is two fold .
1) Am I able to use the standard throttle cables with the FCR's ?
2) bin or keep the TPS ?
I have an ignitech ecu fitted ( from Cobba ) so I can run with or without
FCR 41 Throttle cables
- BamBamTheAprilia
Re: FCR 41 Throttle cables
Keep the TPS if there is a mount for it on the FCR's.
Std throttle cables don't fit.
I've seen 1 trx that had shorter spigot FCR's and he had the filler pipe cut off from the top sump with just a small stub left and then he fitted a flexible rubber hose as the filler tube to stop the fouling of the ACC pump.
