After reading the forum for a fix to the tap leaking, I have done the following.
Purchased a viton o'ring from BSC (Bearing and Power Transmission Solutions), Lonsdale, SA
5x2 size, stretched the spring behind the diaphragm to 40mm (as mentioned in a post) and now have no leaks.
Also glued the elbow in using JB Weld.
Fuel tap fix
- OzzieDave
Fuel tap fix
Re: Fuel tap fix
Thankyou Dave. Just grabbed some JB Weld and will give it a go this evening.
- OzzieDave
Re: Fuel tap fix
Well, the JB Weld has let go, even though it says fuel resistant. I may try some teflon tape soon, see if that will hold.
- Tarwetijger
Re: Fuel tap fix
I used something called "liquid metal" but I'm not sure if that translates well.
Like this
Or this.
Oh I see JB Weld is also 2 components stuff.
Like this
Or this.
- Ragnar
Re: Fuel tap fix
100% right translated
Re: Fuel tap fix
Just place a cable ties around it tap outlet and pull it up to lock it in position.. Won't go anywhere...
