Wiring harness routing.
Bucko
Finally putting the TRX back together and although I took a few photos of the wiring harness routing before I stripped the frame down im not sure im getting the installation right, has anyone got any ideas where I could see some photos or diagrams for the correct route, any help much appreciated, thanks Steve.
Rich
Re: Wiring harness routing.
if you download the manual I think the routing is all in there.
Bucko
Thanks for that, also do you know if the coils mount inboard on the brackets or outboard , it looks like they go on the inside but all the pictures ive seen and access to the mounting screws seems to suggest they mount outboard of the brackets?
FANDANGO
Outward, bolt goes through coil and then thread on the mount. Put the connections to the coil first, fiddley is word I would use...
Rich
I think you are being very restrained there - well done.FANDANGO wrote:fiddley is word I would use...
