Oil pressure after rebuild
Hi guys just wondering if someone can run me through the proper process for refilling oil and checking oil pressure after rebuild, dry engine, I have the cam cover off, an want to see oil come from all galeries. Thanks for any advice
- Con Rod
Re: Oil pressure after rebuild
put in a new filter
put in both sump bolts
have engine assembled with cam cover on and cam gallery bolt out
pour in 3 litres
start the engine and run it util clean oil come out the cam gallery bolt hole
turn off the engine and replace cam gallery bolt
top up oil to top of sight glass
run the engine for about 5 minutes
check the oil level and top up as required
pour in 3 litres
