Shameless Stainless Plug for Australian Members
Post by Con Rod » Tue Nov 11, 2014 5:19 am
These guys are unbelievably good.
https://www.stainlessstore.com.au/index.php
I have ordered from them a few times now and it is always a pleasure. So good I am compelled to plug their business.
So what's so good about them?
Shopping Experience is great. You visit their site, it is well laid out and easy to navigate. They have pretty much anything you need for a bike and you can make really complex order easily. Got example, I order a variety of different nuts and bolts and split pins, I can order just one bolt of every size if I want, no problem. Just pick the bolt or whatever you need, pick the size and pick the quantity. Update cart, pay with your card, easy
Range Aside from some specialist motorcycle fasteners you can get pretty much anything you want on 304 or 316 stainless. Great range, and also split pins, grub screws, nylon nuts, washers etc etc.
Price first off they will match any price, so all good. 2nd off, they shit all over the likes of ProBolt. And then shit all over them again. For example, a single M6*20 stainless steel socket cap will cost you $4.77 from ProBolt. The same bolt will cost you $0.25 from the Stainless Store. Nuf said.
Postage Cost Free delivery on all orders over $75. For orders under $75, a flat delivery fee of $6.50 Australia-wide.
Postage Time This is incredible. Order before noon and there is a good chance you will get it the same day. Otherwise you will get it the next day.
I periodically stock up on a selection of bolts from these people and pretty much just replace bolts as I work on bikes, but you could easily replace every bolt on your bike with stainless for $50 easy. Just sit down with you laptop, pull out the bolt to measure it, add it to your cart, replace and then do the same with the next bolt, ones you have them all in submit your order. If you have a bike thats a few years old and the bolts and shit are looking tired just replace them with stainless.
Now I have heard of people using Coventry fasteners and I used them a few times but this place is where its at.
Buy stuff from these guys and you will never bother going anywhere else.
today I ordered this list of bolts from them.
10 x M4 x 20 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-165) = $2.80
10 x M5 x 10 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-255) = $2.00
20 x M6 x 10 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-375) = $6.00
1 x M6 x 30 Hex socket cap screw G304. Qty: 100 (box) SALE (SHCSMET-304-430) = $24.50
30 x M6 x 35 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-435) = $14.70
20 x M6 x 40 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-445) = $13.20
6 x M6 x 75 Hex socket cap screw G304. Qty: 1 (SHCSMET-304-495) = $9.66
1 x M1.6 x 12 Split pin G304. Pack of 10 (SPLITM-304-135) = $1.50
1 x M2 x 16 Split pin G304. Pack of 10 (SPLITM-304-225) = $2.50
10 x M4 x 8 Csk head socket screw G304. Qty: 1 (SKTCSKM-304-075) = $2.20
10 x M4 x 10 Csk head socket screw G304. Qty: 1 (SKTCSKM-304-085) = $2.40
10 x M4 x 8 Csk phillips head machine screw G304. Qty: 1 (MTSCP-304-275) = $1.50
10 x M4 x 10 Csk phillips head machine screw G304. Qty: 1 (MTSCP-304-285) = $1.30
Sub-Total: $84.26
Standard shipping : $0.00
GST included in total: $7.66
Total: $84.26
I submitted my order at 12.36pm
I got an e-mail at 2.54pm to say my order was shipped.
So in 2 hours and 19 minutes they received my order, picked it out (notice I have a wide selection there), packaged it, labelled it and posted it and updated the order. Excellent service from and Australian company that deserves recognition
wreckage
Re: Shameless Stainless Plug for Australian Members
Post by wreckage » Tue Nov 11, 2014 10:40 am
Well worth bookmarking. Thanks, Con Rod.
:riding:
Post by cobbadiggabuddyblooo » Tue Nov 11, 2014 11:17 am
This is the way to do it if you want to change your bike to cap heads as I,ve chosen with 90% of the bike now completed.
The thing I do need though are M10 shim washers at 1mm and 0.5mm thickness for the front calipers.
I only have 2mm thick washers.
I noticed the M10 washers online here are 1.2mm which may be another option as I need to fill a 2.5mm void.
Post by Con Rod » Tue Nov 11, 2014 12:38 pm
cobbadiggabuddyblooo wrote:This is the way to do it if you want to change your bike to cap heads as I,ve chosen with 90% of the bike now completed.
the calliper bolts are M10 fine (1.25 pitch) just worth noting. I swapped mine for 316 stainless, but they were tricky to find. Like you everything on the bike I have swapped to stainless, mostly cap heads and a few dome heads where needed. There are 2 or 3 very long bolts holding on the oil tank, I could not find replacements for those
With the washers you could make them thinner on a wetstone, I did this for washers for the needles in the carbs, takes ages though
Post by cobbadiggabuddyblooo » Tue Nov 11, 2014 2:14 pm
Yes I know the long sump bolts you mean. That was one of them that was corroded to the side of the sump and snapped off during dismantling 18mths previous on my motor. :lol:
I purchased a Sidchrome Nano tool kit that fits neatly in the tail that will service most of the day to day needs with the bike.
So all I need to carry as extras is a couple of spanners to deal with wheel nuts.
I picked up a small sliding tee bar that fits neatly inside the case too.
http://www.ebay.com.au/itm/Sidchrome-38 ... 3a99a977ce
Post by Con Rod » Tue Nov 11, 2014 11:13 pm
Order arrived this morning, less than 24 hours after I placed it
M.V.
Post by M.V. » Wed Nov 12, 2014 12:53 am
Great news, thanks for the link.
brockzila
Post by brockzila » Wed Nov 12, 2014 1:33 am
cobbadiggabuddyblooo wrote:Yes I know the long sump bolts you mean. That was one of them that was corroded to the side of the sump and snapped off during dismantling 18mths previous on my motor. :lol:
Yes i understand your pain.
One of mine snapped also
Did you manage to find a replacement or did you buy from Yamaha.
Its being a right so and so to get out also .
I intend to swap all bolts possible when rebuilding. I snapped off two cam cap bolts when doing a re-ring on my motor in my 1st bike.
The issue was it was at different times and had to remove the head each time to get the bold removed by a cylinder head shop. I was using a torque wrench both times. I ended up buying new bolts and having them cut down to the correct length by the machine shop and buying a new 3/8 drive torque wrench.
bolts made of putty im thinking
Is it Brock friendly???
wreckage
Post by wreckage » Thu Nov 13, 2014 3:19 am
Quick question for the brains trust... How do I translate Yamaha part numbers into correct sizes for nuts/washers/bolts etc.? .. or do I just need a trained eye?
I'd like to buy stainless bolts, washers and nuts for the windshield/ mirror mounts.
Cheers.
:riding:
Post by Con Rod » Thu Nov 13, 2014 4:26 am
just take them out and measure them,
To measure a bolt you measure the diameter of the threaded part and the length
so a bolt with a 6mm thread diameter and a 30mm thread length will be an M6 * 30
a bolt with a 8mm thread diameter and a 40mm thread length will be an M8 * 40
and so on
I think the screen bolts are M5 * 20 but not sure
wreckage
Post by wreckage » Thu Nov 13, 2014 5:00 am
Con Rod wrote:
so a bolt with a 6mm thread diameter and a 30mm thread length will be an M6 * 10
Er... thanks, but don't you mean M6 * 30? Just checkin'.. ;-)
Cheers.
:riding:
Post by Con Rod » Thu Nov 13, 2014 5:34 am
Cheers.
yep
Smithers
Post by Smithers » Sun Nov 16, 2014 11:06 pm
Got to agree, stainless fastenings have got affordable...... I've found that there's a sometimes a perception that stainless steel is a strong metal (in standard form). 316 and 304 grade fastenings cant compete for strength with a metric Class 8.8 bolt (medium tensile), or even less so, a Class 12.9 cap screw..... in imperial, a metric Class 8 = grade 5 ... imperial grade 8 is even higher .... stainless also fatigue cracks if worked too strenuously or if stretched becomes weak (bolts), and work hardens (this may be where a perception of strength comes from because the metal becomes harder, stiffer, but also brittle, then breaks) .... I have to admit to using more stainless fastenings on products, for the good looks and lasting ability, but don't use them where real force is needed...... The TRX is sporting a few S/S cap screws as well.....hell, they so look good!!
PrfctChaos
Post by PrfctChaos » Mon Nov 17, 2014 1:24 am
I couldn't agree more Smithers. For critical connections replace with identical or higher grade, if in doubt use OEM. But for aesthetics I am a big fan of 316, especially button heads. Recently installed these to get rid of all those ugly rusty bolts. Ordered from Bolt.com.au, they were really good as well.
Bolts & Industrial Supplies
Our Order Number: 9282
Customer Order Number:
Date Ordered: Sun 05 Oct, 2014
Usually ships within: 24 Hours
Products
34 x M6 x 10 Grade 316 Stainless Steel Button Head Socket Screws
(SSBHCS316M610) = AU$10.71
2 x M8 x 20 Grade 316 Stainless Steel Button Head Socket Screws
(SSBHCS316M820) = AU$1.39
10 x M8 x 16 Grade 316 Stainless Steel Button Head Socket Screws
(SSBHCS316M816) = AU$6.30
6 x M5 x 10 Grade 316 Stainless Steel Hexagon Head Set Screws
(SSSS316M510) = AU$1.26
10 x M6 x 20 Grade 316 Stainless Steel Hexagon Head Set Screws
(SSSS316M620) = AU$2.88
40 x M6 G316 Stainless Steel Nyloc Nuts (SSNN316M6) = AU$8.56
6 x M8 G316 Stainless Steel Nyloc Nuts (SSNN316M8) = AU$2.27
30 x M6 G316 Stainless Steel Std Hex Nuts (SSHN316M6) = AU$3.06
4 x M8 x 40mm 10.9 High Tensile Bolt Only Zinc Plated
(HTBOM84010.9Z) = AU$3.86
30 x M6 x 12.5 x 1.2 Grade 316 Stainless Steel Flat Round Washers
(SSFW316M6) = AU$2.32
6 x M8 x 17.0 x 1.2 Grade 316 Stainless Steel Flat Round Washers
(SSFW316M8) = AU$0.55
2 x M8 x 35 Grade 316 Stainless Steel Socket Head Cap Screws
(SSSHCS316M835) = AU$1.14
4 x M8 x 40 Grade 316 Stainless Steel Hexagon Head Bolts
(SSB316M840) = AU$3.52
Total Net Value: AU$47.82
Standard Freight Charge (Postcode Rates): AU$12.00
Total GST: AU$6.00
Total Including GST: AU$65.82
