Speedo to fast
marcimark
Speedo to fast
Hi guys,
the answer is most probably somewhere in this forum, but I couldn't find it.
I installed the white stickers for the gauges, but they didn't work the way I wanted, so had to peek them off again.
Great service from Cut Grafix, as they refunded the full amount.
When I rode the TRX after re-assembling everything, I noticed my speedo showing approx. 120 km/h but I wasn't faster than the other vehicles.
I guess I didn't get the speedo in the correct zero position.
Some advise in how to find the correct position for speedo and tacho?
All help is much appreciated.
Re: Speedo to fast
bluetac and a toothpick stuck to the underside of the speedo face and use that as a pointer marker for 0
bagmaker
Re: Speedo to fast
download free "GPS speedo" app for smartphone or iphone.
Stick phone on bars next to keys and note readings and positions of needles whilst riding along
adjust speedo sticker position to suit
those who can count
and those who cannot
those who can count
marcimark
Re: Speedo to fast
Thanks for the suggestions so far.
Will give it a go, a lot of mucking around to get it right I guess.
Didn't have ant plans for the weekend anyway
I'm not sure if I have made the same mistake for the tacho as well.
What revs should the engine be at 100km/h?
Re: Speedo to fast
depends on gearing, tyre size,manufacturer and profile,
marcimark
Re: Speedo to fast
Thanks Cobba
I'm just after a rough idea with standard tyre size.
The tacho seems out as well.
Followed instructions found on here, but still didn't get it right it seems.
Re: Speedo to fast
Most speedos on bikes and cars from Japan will read slightly fast for the fact that most drivers will sit on the speed limit, ..so allowing for tyres and drivers ,..they set the instrument to about 5--6 kilometres above.
How about find a car or bike owner with a recent model to drive at the required speed and then calibrate yours to suit.
A thumbs up or toot on the horn would suffice.
marcimark
Re: Speedo to fast
Thanks for the assistance.
Used the GPS and an app on the phone.
Speedo 15 k's too fast at all speeds over 50 km/h
Now have to fix it
Now have to fix it
belwin
Re: Speedo to fast
Must be a problem with all trx's I own 2 and one out 15klms ghd other 20
