Hi guys, long time since I've been on here. I need to inspect the float needles on my trx. Can somebody advise if it's possible to remove the float bowls with the carbs in place of do they need to come off.
Thanks Mick
Advice on carbs please.
Mikerhayward
- Rod.s
Re: Advice on carbs please.
You'll need to remove the carbs...Mikerhayward wrote:Hi guys, long time since I've been on here. I need to inspect the float needles on my trx. Can somebody advise if it's possible to remove the float bowls with the carbs in place of do they need to come off.
Thanks Mick
- Tarwetijger
Even if it would be possible, I'm sure you don't want to.
Mikerhayward
Thanks,
seems a bit of a job to have to take the carbs off just to adjust the float levels. the recount to measure again. Always done it when the carbs are easily accessible.
Hey ho.
Mick
Hey ho.
Mick
