Keyster carb kits
pertrx850
Keyster carb kits
Hi!
Has anyone used the Keyster carb kits? (rebuild kit including emulsion tubes, jes etc.)
If so, are they good?
Thanks!
Regards,
Per
Thanks!
Regards,
Per
Re: Keyster carb kits
If it is the Keyster KY - 0570 kit then it's a good kit.
Most of us around Brisbane have the kit and is good quality with value....
Advise fitting the needle clip itself in the lower notch instead of the middle as you would....three notches to the needle I believe....can be a little lean otherwise.
Yep..a good fit up.
Yep..a good fit up.
pertrx850
Thanks!
Regards,
Per
Regards,
Per
pertrx850
Ordered and fitted (partly)! Seems to work fine when running it outside the garage. Longin for spring already
jerrah
Where did these people of Brisbane purchase their Keyster carb kits?
They were advertised on e-Bay..vendor was in Australia which was handy.
- Con Rod
this place sells them in Australia
http://www.motorcyclespareswarehouse.com.au/
specifically, these ones
http://www.motorcyclespareswarehouse.co ... aha/tdm850
Trixed
I bought it from the above workshop in person. They were very helpful and professional. Works really well on the TRX.Con Rod wrote:this place sells them in Australia
Recommend the kit.
