dandywarhol wrote:I had another look at the sleeve today and I think I'll open up the segment cut out holes in the adjuster sleeve - there should be enough room to get the oil past there to the emulator. I blocked off the holes in the damper rod and the lower cap screw and blew down the top of the (dry) damper rod - it didn't let much air past in the minimum damper position. With oil adding additional sealing, I reckon the old, modified, rebound adjuster could be left in place without brazing up the holes and a finer tuning could be made to the rebound damping combined with oil weight - your thoughts Excalibre? Do you think the small hole in the waist of the damper rod would still be required for rebound?
Hello again,
In my opinion you'd need to remove virtually all of the material around the cut-outs to ensure there was no resistance during high speed compression damping to allow the emulator to work as designed.
How about this for an idea?:
Remove most of the metal around the cut-outs, including the central section, leaving 3 small lugs around the perimeter. Make a special tool using an appropriate diameter pipe or old socket with notches cut in the end to engage the lugs. This tool would be used to rotate the sleeve to adjust rebound damping (fork spring and emulator removed).
You do need to leave the original small hole in the waist open otherwise the fork will essentially not be able to rebound at all (with adjuster set to 4). The only way for the oil to return would be past the bushes. See figure 3.19 at the bottom of this page
http://www.racetech.com/HTML_FILES/DampingRodForks.HTML
During the rebound cycle the oil flows from chamber 'B' through the centre of the damping tube to chamber 'A'. The waist hole plus the selected adjuster hole control the rebound damping rate.
When the adjuster sleeve is set to position 4 the waist hole is the only available passageway.
I'm really interested to hear how it works out, you could revolutionise the emulator rebound damping world!
If that all seems like too much trouble, just braze closed the extra holes you drilled in the waists of your original tubes and you'll be back to the equivalent of position 4.
