Oops!
Was changing the starter motor last week and noticed this. Must have been at Anglesey while scraping the rearsets.
Have adjusted ride height and raised rearsets further since then so shouldnt wear it right through now.
Dave
My generator cover.
- Silver
My generator cover.
- trixynut
Re: My generator cover.
Ga erne Dave, go for it!!
I've seen bikes with a small crash bung fitted to that hole in your picture below the cover.
is that Suzuki front end lower than a standard TRX? also, you running a 120/60 or 120/70 front tyre?
- Silver
no its not suzuki, its CBR600 F2 i think, first of the cartridge forks anyway. Fitted before i got it, but they are faultless and front end is really planted. 120/60 supercorsa on the front. Since Anglesey i messed with ride height at the back and raised the rearsets, but now i have fitted an R6 shock and i beleive the spring is new on that so should be better. Havent ridden it yet, plus FCR's are on it now.
As far as i know its about the same height at the front but havent measured it.
ac@39
